  4. DC DC 10W
  5. Hi-Link DCDC isolated power module URB4805S-10WR3 URB4824S/03S/09S/12S/15S-10WR3 4:1 wide voltage input single output power converter module
    $4.41
URB48xxS-10WR3-1
  • Ultra wide range input (4:1), output 10W
  • Conversion efficiency 88% (Typ)
  • Isolated voltage 1500Vdc
  • Ultra-low standby power consumption:0.036W(Typ)
  • Ultra-fast startup: 5ms (Typ)
  • Operating temperature range:-40°C~+85°C
  • Input undervoltage,output short circuit , overcurrent protection
  • Metal shell, low output ripple
Item
Opearating conditionsMin.Typ.Max.Unit
Input current(full load/ no load)24VDC nominal input series, nominal input voltage3.3V-429/5440/12mA
48VDC nominal input series, nominal input voltageOther-484/5496/12
Reflected ripple 24VDC nominal input series, nominal input voltage3.3V-190/4215/8
48VDC nominal input series, nominal input voltageOther-242/4248/8
Impulse voltage (Isec. max)24VDC nominal input series, nominal input voltage-0.740-mA
48VDC nominal input series, nominal input voltage-0.730-
Start voltage24VDC nominal input series, nominal input voltage--50VDC
48VDC nominal input series, nominal input voltage--100
Input undervoltage protection24VDC nominal input series, nominal input voltage5.56.59
48VDC nominal input series, nominal input voltage1215.518
Start timeNominal input voltage and constant resistance load-10-ms
PI type
Hot plug
Not support
Remote control terminal (Ctrl)*module turned onCtrl floating or connected to TTL high level (3.5-12VDC)
module turned offCtrl connected to GND or low level (0-1.2VDC)
Input current at shutdown-610mA
Note: *Ctrl control pin voltage is relative to input pin GND.
ProjectOperating and test conditions+V01-V02
Output loadload percentage0%-100%0%-100%
-±1.0%±2.0%-±2.0%±3.0%
±0.2%±0.5%-±1.5%±2.0%
Load adjustment
20%~100% rate
load, balanced
±0.5%
±1.0%-±4.0%±5.0%
Ripple & NoisePure resistive load, 20HMz bandwidth, peak-to-peak--80mVp-p120mVp-p-80mVp-p120mVp-p
Start delay time
1mS
1mS
Dynamic response step deviation25% nominal load step-±3.0%±5.0%-±3.0%±5.0%
Dynamic response recovery time-300us500us-300us500us
Output overcurrent protectionFull voltage range input110%lo150%lo200%lo
Output short circuit protectionFull voltage range inputSustainable, self-healing
Note: ①When tested under the working conditions of 0%-100% load, the index ofthe load adjustment rate is +5%.
②0%-5% load ripple & noise is less than or equal to 5% Vo. Test methofor ripple and noise The twisted pair test method can add capacitive load to the output to reduce light load ripple.
