Visitor1503
Price$91.60
Maximum input current | 85V input voltage, full load output | -- | -- | 3 | A |
| Maximum inrush current | With a 5.6Ω resistor wired inserieson the input line,matched with a 20mm diameter thermistor, for 220VAC input | -- | -- | 20 | A |
| No-load input current | Rated input voltage | -- | -- | 2 | W |
| Input surge voltage (1sec. max.) | Out-of-range input will cause permanent damage | -- | -- | 315 | VAC |
| Turn-on voltage | -- | -- | 85 | ||
| Input under-voltage protection | No-load test | -- | -- | 80 | |
Input voltage frequency | 47 | -- | 63 | Hz | |
| PF value | 220VAC Input, Full Load Output | 95 | -- | -- | % |
| Output overcurrent protection | 8.8 | -- | 10.8 | A | |
| Isolation Voltage | Input-output | Test time 1 min, leakage current <3mA | -- | -- | 2500 | VDC |
| Switching frequency | -- | 280 | -- | KHz | ||
