  4. DC DC 1W
  5. Hi-Link B0305LS/B0312LS/B0303LS/B0309LS/B0315LS/B0324LS-1WR3 DC to DC 1W step down power converter module
    $0.61
BxxxxLS-1WR3-1
  • Constant voltage input, isolated unregulatedoutput, power 1W
  • Isolation voltage: 1500VDC
  • Low no-load power consumption: 0.025W (Typ.)
  • Efficiency: up to 90%
  • Working environment temperature: -40°C~+85°C
  • Failure-free time MTBF23.5 million hours(3500000Hrs)
  • Output short circuit protection: continuous short
  • circuit protection, automatic recolvery
  • Small SIP package, plastic housing
  • International standard pin mode
  • Ripple/Noise (20MHz bandwidth): 30mVp-p(Typ.)
Items Working conditionsMin.Typ.Max.Unit
Input current
(fully loaded/
unloaded)
3.3VDC Input--378/6--/12mA
5VDC Input--224/5--/10
12VDC Input--93/3--/5
15VDC Input--74/2--/4
24VDC Input--47/1--/2
Reflected Ripple Current
--15--mA
Impulse voltage (Isec.max)3.3VDC Input-0.7--5VDC
5VDC Input-0.7--9
12VDC Input-0.7--18
15VDC Input-0.7--21
24VDC Input-0.7--30
Capacitive filtering
Hot plug
Not available
ItemsWorking and test conditions Min.Typ.Max. Unit
Output loadLoad percentage 10--100%
Output VoltageAccuracyRefer to Error Envelope Curve ----±15.0%
Linear adjustment rate
Input voltage
variation ±1%
3.3V Output----±1.5%
Others----±1.2 %
Load Regulation
10%~100%
Load
3.3VDC Output --18
5VDC Output --12
9VDC Output --8
12VDC Output --7
15VDC Output --6
24VDC Output--5
Ripple & Noise
Pure resistive load, 20MHz bandwidth,
peak-to-peak
--3080mVp-p
Temperature Drift CoefficientFull load --
--±0.03%/°C
Note: ①The test method of ripple and noise is twisted pair test method
