  4. 1/16 brick power module
  5. Hi-link DCDC isolated power module UCB2405SBO/UCB2424SBO/UCB2409SBO/UCB2412SBO/UCB2415SBO-10WR3
    $3.22
UCB24xxSBO-10WR3-1
The UCB24_SBO-10WR3 series features an output power of 10W, a 4:1 wide input voltage range, and an efficiency of up to 88%. With a standard isolation voltage of 1500VDC and an operating temperature range of -40°C to +85°C, these converters incorporate protections against input undervoltage as well as output overcurrent, short-circuit, and overvoltage conditions. They are widely used in the communications sector for equipment such as switches, repeaters, smart communication gateways, GPS clock synchronization systems, and DC power supplies for 4G/5G base stations.
  • Wide input voltage range: 9V–36V
  • Efficiency up to 88%
  • Isolation voltage: 1500VDC
  • Input under-voltage protection; output over-current, short-circuit, and over-voltage protection
  • Operating temperature: -40°C~ +85°C
  • Standard 1/16 brick package
Product Characteristic
Input feature
ItemsOperating environmentMin.Typ.Max.Unit.
Input current (full load/no load)Nominal input voltage -502/5515/15mA
Reflected ripple current
-50-
Surge voltage (1 sec. max)
-0.7-50VDC
Starting voltage
--9
Input undervoltage protection
5.56.5-
Startup timeNominal input voltage and constant- resistance load--100ms
C-type filtering
Hot-swapping
Not supported
Remote control pin (Ctrl)*
Module enabled
Leave the Ctrl pin floating or connect it to a
TTL high-level signal (3.5-12 VDC).
Module shutdown
Connect Ctrl to GND or a low-level signal (0-1.2 VDC).
Input current at shutdown
610mA
Note: *The voltage of the Ctrl control pin is relative to the input pin GND.
Output feature
Output Voltage Accuracy5% - 100% Load-±1±3%Vo
Line RegulationFull load, input voltage ranging from low to high-±0.2±0.5
Load Regulation ①5% - 100% Load-±0.5±1
Transient Recovery Time25% load step change, nominal input voltage-300500μs
Transient Response Deviation
25% load step change, nominal input voltage 5V Output
Other  Voltages
±5
±3
±8
±5
Temperature drift CoefficientFull Load--±0.03%/℃
Ripple & Noise ②20MHz bandwidth, 5% - 100% Load-60120mVp-p
Output Overvoltage ProtectionInput Voltage Range----
Output Overcurrent Protection--150--
110150190%lo
Short-Circuit ProtectionSustainable, self-recovering
Note: ①Under 0%-100% load conditions, the load regulation is ±3%
②For the 0%-5% load range, ripple and noise are ≤5% Vo. Ripple:and noise are measured using the parallel-line test method.
General feature
Isolation VoltageInput to Output; test duration: 1 minute; leakage current than1mA1500--VDC
Insulation ResistanceInput - Output isolation voltage: 500 VDC1000--MΩ
Isolation CapacitanceInput - Output, 100kHz/0.1V-1000-pF
Operating TemperatureSee Figure 1-40-+85℃
Storage Temperature
-55-+125
Storage HumidityNo coagulation5-95%RH
Vibration-10–150Hz, 5G, 0.75mm, along X, Y and Z
Switching Frequency*PWM Model-275-kHz
Mean Time Between Failures MIL-HDBK-217F @25℃1000--K hours
UCB24xxSBO-10WR3-5
UCB24xxSBO-10WR3-2
UCB24xxSBO-10WR3-3
UCB24xxSBO-10WR3-4
