  3. Smart Device and Accessories
  4. Hi-link Intelligent Gateway IR03 Remote Networking Gateway RS232/RS485 Serial Port to Ethernet WiFi Remote PLC Monitoring DTU Module Router
    $39.98
1. Product Overview
HLK-IR03 is a multi-functional intelligent gateway that can establish a virtual LAN across the Internet. It provides remote interconnection solutions for all network devices, including network equipment, industrial control equipment, IoT devices, printers, PLCs, NAS file servers, cameras, PCs, and more.
In addition, the gateway can serve as an IoT edge gateway, supporting RS232/RS485 serial device access, fully covering traditional serial server (DTU) functions, and providing users with personalized customized services for remote data collection and device control.
2. Product Parameters
Table1. electric parameters
TypleParametersDescription
Power SupplyPowerTerminal interface and DC power interface, supporting wide voltage supply: DC5-36V, typical value: 12V
Hardware interfacesResetPress and hold the button for 3 seconds to release and restore the factory settings
DB9 interfaceStandard RS232 male interface
RS485 interfaceTerminal interface, supports RS485, supports 1200-924600Kbps
Ethernet portConnect standardRJ45, Support data and network indicator lights, 10/100Mbps, cross direct adaptive
WiFiAntenna portStandard SMA interface, supporting WiFi6 (802.11ax)
Working modelSupport STA and AP
IndicatorPowerPower indicator light, always on after the device is powered on
WiFi(System operation indicator light)Slow flashing, no connection on the link
Double flashing, normal link connection
Flash, network layer connection is normal
NETData transmission, flashing
Overall dimensionsUnit:mm96.0x 90.0x29.0
Installation wayinstallationhook-on
Temperature rangeoperation temperature-40℃~ +85℃
storage temperature-40℃ ~ +105℃
Humidity rangeoperation humidity5%~95% (no condensation)
Software function
parameters settingConfiguration tool, built-in web
network protocolIP、TCP、ARP、ICMP、IPV4、DHCP、DNS
communication link3 channels, 1 TCP connection+1 MQTT+1 UDP
SSL encryptionSupport encryption operations for MQTT protocol transmission
HLK-IR03-1
HLK-IR03-2
