  4. AC DC 20W
  5. AC DC bare board power module 220 rpm 5V12V isolated voltage reduction and stabilization input 85-305 HLK-20LD05/20LD12/20LD24L
    $2.55
HLK-20LDxxL-1
  • Global universal input voltage(85-305Vac)
  • Input and output isolation voltage 2000VAC
  • Low power consumption, green enviroment protection, no-load loss<0.15W
Working Temerature-40—+85 ℃
Storage temperature-40—+80 ℃
Relative humidity5—95 %
Altitude≤5000 m
Vibration coefficient10~500Hz,2G10min./1cycle, 60min.each along X,Y,Z axes.
Rated input voltage100-277Vac
Input vlotage range85-305VAC/100-430VDC
The maximum input CURRENT≤0.3A
Input inrush current ≤40A
Input low start≤200mS
External fuse recommended3.15A/300Vac or 10Ω wire wound resistance, Slow blow
