  4. 1/16 brick power module
  5. Hi-link DCDC isolated power module VCB4805SBO/09SBO/12SBO/15SBO/4824SBO-20WR3 1/16 brick power supply converter
    $3.96
VCB48xxSBO-20WR3-1
The VCB48_SBO-20WR3 series products have an output power of 20W, a wide voltage input range of 2:1, an efficiency of up to 90%, a conventional isolation voltage of 1500VDC, and an allowable working temperature of -40 ° Cto+85 ° C. They have input undervoltage protection, output overcurrent, short circuit, and overvoltage protection functions, and are widely used in the communication field, such as switches, repeaters, intelligent communication gateways, GPS clock synchronization, and 4G/5G base station related DC power supply equipment.
  • Wide input voltage range: 36V~75V
  • Efficiency up to 90%
  • Isolation voltage 1500VDC
  • Input undervoltage protection, output overcurrent, short circuit, overvoltage protection
  • Working temperature range: -40 ° Cto+85 ° C
  • Standard 1/16 brick encapsulation
Product Characteristic
Input features
ItemOperating environmentMinTyp.MaxUnit
Input current (full load/no load)Rated input voltage -474/15485/30mA
reflected ripple current
-50-
Impulse voltage (1sec. max)
-0.7-100VDC
Starting voltage
--36
2831-
Startup timeNominal input voltage and constant resistance load--100ms
Capacitive filtering
Hot-swapping
Non support
Remote control foot (Ctrl)
Module activation
Ctrl floating or connected to TTL high level (3.5-12VDC)
Module shutdown Ctrl connected to GND or low level (0-1.2VDC)
Input current when turned off
610mA
Note: The voltage at pin I of * C control is relative to the input pin GND.
Output features
Output Voltage Accuracy5% - 100% Load-±1±39Vo
Line RegulationFull load, input voltage varies from minimum to maximum-±0.2±0.5
Load Regulation<sup>①</sup>5% - 100% Load-±0.5±1
Transient Recovery Time25% load step change, nominal input voltage-300500μs
Transient Response Deviation
25% load step change, nominal input voltage 5V/6VOutput
Other Output Voltages
3.3V/5v output
others
±5
±3
±8
±5
Temperature CoefficientFull Load--±0.03%6/C
Ripple & Noise<sup>②</sup>20MHz bandwidth, 5% - 100% Load-100150mvp-p
Output Overvoltage ProtectionInput Voltage Range90--110%Vo
Output Overcurrent Protection--150--
110150190%lo
Short Circuit ProtectionContinuous, Auto-recovery
General features
Isolation VoltageInput to Output, test duration 1 minute, leakage current <1mA1500--VDC
Insulation ResistanceInput to Output, test voltage 500VDC1000--MΩ
Isolation CapacitanceInput to Output, 100kHz/0.1V-1000-pF
Operating TemperatureSee Figure 1-40-+85℃
Storage Temperature
-55-+125℃
Storage HumidityNon-condensing5-95%RH
Vibration-colspan="4"10–150Hz, 5G, 0.75mm, along X, Y and Z axes--
Switching Frequency*PWM Mode-275-kHz
Mean Time Between Failures (MTBF)MIL-HDBK-217F @25℃1000--K hours
