  4. 75W brick power module
  5. Hi-Link DC DC1/4 brick power module HLK-75MQ110S12A 110V to 12V isolated and stabilized single circuit 75W
    $39.26
HLK-75MQ110S12A-1(1)
Full-load output at 43 V input voltage----1.8A
----10mA
Input surge voltage (1sec. max.)
Input values outside this range may cause permanent damage.
-0.7--185VDC
Start-up voltage
----43
Input Undervoltage ProtectionNo-load testing,
Full-load testing will trigger overcurrent protection prematurely
----40
Remote-controlled foot(CNT)
Positive logic: The CNT pin is left floating or connected to 3.5–15 V to power on;
connect it to 0–1.2 V to power off.
Reference Voltage -
VIN
Negative logic: If the CNT pin is left floating or connected to 3.5–15 V, the device
powers off; if connected to 0–1.2 V, the device powers on.
Output voltage regulation accuracy
Nominal input voltage,  from 10%  load--±0.2±1.0%
Linear adjustment rate
At full load, the input voltage ranges from low  to high
--±0.1±0.2
Nominal input voltage,  from 10% to 100% load
--±0.1±0.5
Transient Recovery Time25% load step change (step rate : 1A/50us)--200250uS
Temperature  coefficientFully loaded-0.02--+0.02%/℃
Ripple&Noise
20 MHz bandwidth, tested with an external capacitor of 220 uF or higher
--80120mVp-p
-20--+10%
Remote compensation of Output Voltage (Sense)
Over-Temperature ProtectionMaximum surface temperature of the product's metal substrate105115125℃
125--140%
Output overcurrent protection6.9--8.7A
Output Short-Circuit ProtectionIntermittent,sustainable,self-recovering
VAC
Input - HousingTest time 1 min, leakage current<3mA----2100VAC
Output - HousingTest time 1 min, leakage current<3mA----500VAC
--250--KHz
Mean time between failures150----K hours
