  4. Full brick power module
  5. Hi-Link ACDC Full-Brick Power Module 700AFFS24, 220V to 24V, Isolated Regulated Single Output, 700W
    $122.12
HLK-700AFFS24-1
  • Wide input voltage range: 3:1
  • Efficiency as high as 91%
  • Low no-load power consumption
  • Operating Temperature Range: -40°C to +105°C
  • High insulation voltage: Input to output 2500 VAC, input to enclosure 2100 VAC
  • Input undervoltage protection; output overcurrent, overvoltage, overtemperature, and short-circuit protection
  • Standard full- brick form factor
  • CE Certification
AC Input Start-up
Operating Voltage
----90VAC
AC Input Under-Voltage
Protection
----80
AC Input Over-Voltage
Protection
290--310
Input surge voltage (1sec. max.)
Inputvaluesoutsidethis range may cause
permanent damage.
-0.7--315
DC Input Start-up Operating Voltage
----145VDC
DC Input Under-Voltage
Protection
----135
DC Input Over-Voltage
Protection
425--435
Maximum Input Surge
Current
5.6 Ω thermistor with 20 mm diameter connected
in series on input line, 220 VAC input
----40A
Input Voltage Frequency
47--63Hz
Start-up Time
----5S
Standby Power Consumption
220VAC Input--1020W
Power Factor220VAC Input, Full-Load Output95----%
