  4. DC DC 1W
  5. HLK-Link DC-DC Isolation Voltage Power ModuleWRB2405S-1WR3/WRB2412S-1WR3 WRB1203S/WRB1209S/WRB4815S-WRB4824S-1WR3 1W
    $0.42
WRBxxxxS-1WR3-1
  • Ultra-small SIP-8 package
  • 2:1 wide input voltage range
  • Operating temperature: -40°C ~ +85°C
  • Isolation voltage: 1500VDC
  • Low ripple & noise
  • Self-recovering short-circuit protection
  • No-load power consumption as low as 0.12W
  • Input under-voltage protection, output short-circuit and over-current protection
ProjectWorking conditionsMin.Typ.Max.Unit
Input Current
(Full Load / No Load)
5V input--281/40290/60
12V input--111/50114/30
24V input--55/657/10
48V input--27/428/6
Reflected ripple current
--50--
Impulse voltage
-0.7--50VDC
Starting voltage
--9
Input undervoltage protection
5.56.5--
Capacitor filtering
Hot swap
Not supported
Remote Foot (Ctrl)*Module enabledCtrl pin open or at high level (greater than 0.8V)
Module shutdownCtrl pulled low (less than 0.6 VDC)
Note: *For the description of the remote control pin (Ctrl) function, please refer to the "Typical Application Reference Circuit" section in this manual.
ItemOperating and test conditionsMin.Typ.Max.Unit
Output voltage accuracy5%~100% load, input voltage range3.3V/5V output--±3.0±5.0%
Others--±1.0±3.0%
Line regulationFull load, input voltage from low to high--±0.5±1.0%
Load regulation5% ~ 100% load--±0.5±1.5%
Transient recovery time25% load step change--±5±8mS
Transient response deviation--±3±5%
Ripple & NoisePure resistive load, 20 MHz bandwidth, peak-to-peak--50100mVp-p
Temperature drift coefficientFully loaded--±0.02±0.03%/℃
Output short-circuit protection
Sustainable, self-recovering
Note: 1. The test method for ripple and noise is the twisted-pair test method.
