  4. AC DC 200W
  5. Hi-link AC DC half brick isolated power module HLK-200AHFS48 220V to 24V/8.3A stabilized single circuit 200W
    $91.60
200W product list-3 拷贝 (1)
85V input voltage, full load output----3A
Maximum inrush currentWith a 5.6Ω resistor wired inserieson the input line,matched with a 20mm diameter thermistor, for 220VAC input----20A
----2W
Input surge voltage (1sec. max.)Out-of-range input will cause permanent damage----315VAC
----85
Input under-voltage protectionNo-load test----80
Input voltage frequency
47--63Hz
PF value220VAC Input, Full Load Output95----%
--±0.1±0.2
--±0.2±0.5
Ripple&Noise20MHz bandwidth, external capaciry ≥220μF--150240mVp-p
-10--+10%
125--140%
8.8
--10.8A
Isolation VoltageInput-outputTest time 1 min, leakage current <3mA----2500
--280--KHz
dimension 拷贝
