Visitor1410
Price$6.36
Product Characteristics
Global universal input voltage 85~265VAC
Input/output isolation withstand voltage 3000VAC
Low power consumption, green environmental protection, no-load loss<0.3W
Low ripple, low noise
High reliability, long-life design
Good output short circuit, overvoltage and overcurrent protection and self recovery
Meet the waterproof and dustproof IP65 standard
Using high-quality environmentally friendly waterproof thermal conductive adhesive for sealing, moisture-proof and vibration proof,
Complies with UL/CE/EMC and safety testing requirements
Applied in industries such as automation control, communication equipment, and instrumentation
| Working temperature | -25°C~+60°C |
| Sotrage temperature | -40°C~+80°C |
| Relative humadity | 5~95%RH |
| Cooling method | natural cooling |
| Atmospheric pressure | 80~106Kpa |
| Altitude | ≤2000m |
| Vibration | Vibration coefficient 10~500Hz, 2G10min./1 cycle, 60min.each a-long X, Y, Z axes meet the transportation requirements of second-class highway |
Electrical Characteristics
| Input characteristics (testing in normal temperature) | |
| Rated input voltage | 100-240VAC |
| Input voltage range | 85-264VAC/120-350VDC |
| Maximum input current | ≤0.4A |
| Input frequency | 47-63Hz |
| Enter the startup time | ≤2000ms |
| Enter the startup time | MTBF>100,000H |
| Recommended external fuses | 2A/250VAC(Slow circuit breaker) |
| Output characteristics | |
| Load adjustment rate | ±0.2% |
| Power on/off overshoot amplitude | ≤5%Vo |
| Output Ripple&Noise | ≤100mVp-p |
