Visitor3106
Price$4.35
Global universal input voltage(85-305Vac)
Input and output isolation voltage 2000VAC
Low power consumption, green enviroment protection, no-load loss<0.15W
| Working Temerature | -40—+85 ℃ |
| Altitude | ≤5000 m |
| Vibration coefficient | 10~500Hz,2G10min./1cycle, 60min.each along X,Y,Z axes. |
| Rated input voltage | 100-277Vac |
| Input vlotage range | 85-305VAC/100-430VDC |
| The maximum input CURRENT | ≤0.75A |
| Input inrush current | ≤50A |
| Input low start | ≤200mS |
| External fuse recommended | 3.15A/300Vac, Slow blow |
Output Features (5V/6000mA)
| No-load rated output voltage | 5±0.2Vdc |
| Full-load rated output voltage | 5±0.2Vdc |
| Short term maximum output current | ≥6200mA |
| Rated output current | 6000mA |
| Load regulation rate | ±1% |
Output Features (9V/3330mA)
| No-load rated output voltage | 9±0.2Vdc |
| Full-load rated output voltage | 9±0.2Vdc |
| Short term maximum output current | ≥3330mA |
| Rated output current | 3530mA |
Output Features (12V/2500mA)
| No-load rated output voltage | 12±0.2Vdc |
| Full-load rated output voltage | 12±0.2Vdc |
| Short term maximum output current | ≥2700mA |
| Rated output current | 2500mA |
Output Features (15V/2000mA)
| No-load rated output voltage | 15±0.2Vdc |
| Full-load rated output voltage | 15±0.2Vdc |
| Short term maximum output current | ≥2200mA |
| Rated output current | 2000mA |
Output Features (18V/1670mA)
| No-load rated output voltage | 18±0.2Vdc |
| Full-load rated output voltage | 18±0.2Vdc |
| Short term maximum output current | ≥1870mA |
| Rated output current | 1670mA |
Output Features (24V/1250mA)
| No-load rated output voltage | 24±0.2Vdc |
| Full-load rated output voltage | 24±0.2Vdc |
| Short term maximum output current | ≥1450mA |
| Rated output current | 1250mA |
Output Features (48V/625mA)
| No-load rated output voltage | 48±0.2Vdc |
| Full-load rated output voltage | 48±0.2Vdc |
| Short term maximum output current | ≥825mA |
| Rated output current | 625mA |
