  4. 24G radar sensor module
  5. Hi-link 24G millimeter wave high-precision 3-4 multi-target human body state LD2423 trajectory tracking radar module test kits
    $9.98
HLK-LD2423: https://drive.google.com/drive/folders/11BpACC7glaWITT5-4-Q1xA3sQhjgHFR3
1. Product Overview
Target tracking refers to the real-time continuous tracking of the target position within the monitoring area, and the accurate measurement of parameters such as distance, angle, and velocity.
HLK-LD2423 is a high-precision multi-target recognition millimeter wave radar sensor designed for conventional indoor environments such as homes, offices, and hotels, which can achieve real-time positioning and motion tracking of multiple human targets.
The sensor hardware integrates two AIoT millimeter wave radar chips, two one transmitter and one receiver microstrip antenna arrays to form a two transmitter and two receiver module, paired with a cost-effective MCU and complete peripheral circuits. The intelligent algorithm firmware is based on FMCW frequency modulation continuous wave system, combined with advanced signal processing technology dedicated to radar chips, to ensure positioning accuracy and multi-target tracking stability.
2. Product Features
  • The 24GHz ISM frequency band can be certified by FCC, CE, and non commission spectrum regulations;
  • 5V power supply, wide voltage range of 4.5-5.5V;
  • Accurate motion target positioning and tracking
  • Real time reporting of detection results, with a large detection angle of 130 ° for horizontal detection and 70 ° for vertical detection;
  • HLK-LD2423 size: 23mmX42mm
3. HLK-LD2453 Specification Parameters
No.ProjectFunction descriptionParameters
1Number of people,this module can detect the number of peopledynamic 3-4 people, static 2-3 people
2Detection distancedetection distance and conditions of this module8m
3Distance resolutionthe minimum distance distinguished by this module
4Distance accuracythe absolute error of this module in distance
5Horizontal detection anglethe maximum horizontal angle that this module can detect
6Vertical detection anglethe maximum vertical angle that this module can detect
7Angle resolutionthe minimum angle distinguished by this module
8Angle accuracythe absolute error of this module in terms of angle
9OTA functiononline upgrade function
No.ProjectParameters
1
operating frequency band24GHz-24.25GHz
2Working bandwidth250Mhz
3EIRP13dBm
4Modulation schemeFMCW(Frequency Modulated Continuous Wave)
5Working voltage5V
6Average current≤127mA
7Operating temperature-40℃--85℃
8Storage temperature-40℃--85℃
