  4. AC DC 60W
  5. HLK-Link AC-DC power module, 220V to 5V/12V/24V isolated step-down voltage regulator, 60LD09/60LD12/60LD15/60LD18/60LD24/60LD36
    $9.54
HLK-60LDxx-1
  • Ultra-thin, ultra-small, smallest volume in the industry
  • Universal global input voltage (85~305Vac)
  • Low power consumption, eco-friendly; no-load power loss <0.20W
  • Low ripple & low noise
  • Built-in output short-circuit and overcurrent protection with auto-recovery
  • High efficiency & high power density2 / 18
  • Input-output isolation withstand voltage: 3000~4000Vac; short-circuit test duration: 30s, leakage current ≤5mA
  • 100% full load aging and testing
  • High reliability, long life design, continuous working time is greater than 100,000 hours
  • Meet UL, CE requirements; product design to meet EMC and safety testing requirement
  • Using high-quality environmentally friendly waterproof thermal conductive adhesive for sealing, moisture-proof and vibration proof, complying with IP65 waterproof and dustproof standard.
  • Economic solutions with high cost-effectiveness
  • Can work without external circuitry
  • 1 year quality guarantee period
  • Applicable for altitudes ranging from 2000m to 5000m
Working Temerature-40—+85 ℃
Storage temperature-40—+80 ℃
Relative humidity5—95 %
Cooling methodNatural cooling
Altitude≤2000-5000 m
VibrationVibration coefficient 10~500Hz,2G10min./1cycle, 60min.each along X,Y,Z axes.
Meets requirements
for secondary road
transportation
Items
Technical Requirement
  Rated input voltage  100-277Vac
  Input vlotage range   85-305VAC/DC100-430VDC
  The maximum input CURRENT   ≤2A
  Input inrush current    ≤60A
  Input low start   ≤300mS
  Long-term reliablity    MTBF≥100000H
  Recommended External Fuse   3.15A/300Vac ,Slow blow
Output Features  (9V/6670mA)
Item
Technical RequirementUnitNotes
No-Load Output Voltage
9±0.2Vdc
Full-Load Output Voltage
9±0.2Vdc
Short-Term Max Output Current
≥6800mA
Rated Output Current6670mA
Voltage regulation±2%
Load regulation±1.5%
Input low voltage efficiency
Vin=115Vac, Output full load ≥ 87%
Input high voltage efficiency
Vin=230Vac, Output full load ≥90%
Output ripple & noise (mVp-p)
≤100
Rated input voltage, full output load. Using a 10X,
20MHz bandwidth oscilloscope,
The load end is tested with 10uF and 0.1uF capacitors.
mV
Switching on/off overshoot amplitude
(Rated input voltage, output plus 10% load) <5%Vo
Output over-current protection
Output 110-160% of maximum loadA
Short circuit directly during normal output, and
automatically resume normal operation after the short
circuit is removed
No damage to
the unit
Output Features (12V/5000mA)
No-load  output voltage12.0±0.2Vdc
Full-load  output voltage12.0±0.2Vdc
Short term max output current≥5200mA
Rated output current5000mA
Voltage regulation ±2%
Load regulation  ±1.5%
Switching on/off overshoot amplitude(Rated input voltage, output with 10% load) ≤5%Vo
≤120mV
Rated input voltage, full output load. Using a 10X, 20MHz
Output Features (15V/4000mA)
No-load  output voltage15.0±0.2Vdc
Full-load  output voltage15.0±0.2Vdc
Short term max output current≥4200mA
Rated output current4000mA
≤120mV
Output Features (18V/3300mA)
No-load  output voltage18.0±0.2Vdc
Full-load  output voltage18.0±0.2Vdc
Short term max output current≥3530mA
Rated output current3330mA
≤120mV
Output Features (24V/2500mA)
No-load  output voltage24.0±0.2Vdc
Full-load  output voltage24.0±0.2Vdc
Short term max output current≥2700mA
Rated output current2500mA
≤120mV
Output Features (36V/1670mA)
No-load  output voltage36.0±0.2Vdc
Full-load  output voltage36.0±0.2Vdc
Short term max output current≥1870mA
Rated output current1670mA
≤120mV
Output Features (48V/1250mA)
No-load  output voltage48.0±0.2Vdc
Full-load  output voltage48.0±0.2Vdc
Short term max output current≥1450mA
Rated output current1250mA
≤120mV
Output Features (55V/1090mA)
No-load  output voltage55.0±0.2Vdc
Full-load  output voltage55.0±0.2Vdc
Short term max output current≥1300mA
Rated output current1090mA
≤120mV
HLK-60LDxx-5
HLK-60LDxx-8
