Visitor1713
Price$323.60
HLK-5000QYL150 is a 5KW single output chassis type AC to DC/DC to DC power supply. The input voltage range of the entire series is 180-264VAC/250-370VDC, and it can provide DC output that can meet most industrial needs. Each model can be cooled by an internal speed controlled fan, with a working temperature of up to 60 ℃. Built in multiple functions such as adjustable output voltage and current, remote on/off control, auxiliary power supply, etc. provide various design flexibility.
HLK-5000QYL12 | 356*216*80mm (L*W*H) | 5000W | 12V | 0~333A | |
HLK-5000QYL24 | 24V | 0~208A | |||
HLK-5000QYL36 | 36V | 0~138.8A | |||
HLK-5000QYL48 | 48V | 0~104A | |||
HLK-5000QYL72 | 72V | 0~69A | |||
HLK-5000QYL96 | 96V | 0~52A | |||
HLK-5000QYL110 | 110V | 0~45A | |||
HLK-5000QYL150 | 150V | 0~33A | |||
HLK-5000QYL220 | 220V | 0~22.7A |
Laser related machines
UV curing equipment
Charging equipment
Aging equipment
Altitude | ≤2000 | m | |
AC current | < 55A | A | |
Project name | HLK-5000QYL-12 | HLK-5000QYL-24 | HLK-5000QYL-36 | HLK-5000QYL-48 | HLK-5000QYL-72 | Unit |
Rated current | 333A | 208A | 138.8A | 104A | 69A | A |
Current range | 0~333A | 0~208A | 0~138.8A | 0~104A | 0~69A | A |
Output ripple | 250mV | 270mV | 360mV | 400mV | 500mV | (mVp-p) |
Project name | HLK-5000QYL-96 | HLK-5000QYL-110 | HLK-5000QYL-150 | HLK-5000QYL-220 | Unit | |
Rated current | 52A | 45A | 33A | 22.7A | A | |
Current range | 0~52A | 0~45A | 0~33A | 0~22.7A | A | |
Project name | Unit | |
