Visitor3575
Price$2.13
1. Product Description
HLK-DL04A is a high-power DC brushless motor electronic speed regulation module developed by Hailingke Electronics.
Output performance: 20A
Power input: 12V
Control signal type: PWM
Throttle signal frequency range: 50HZ-400HZ
Signal pulse width: 0.9ms-2ms
2. Product features and advantages
2.1 Characteristics
High power
High current
Heat sink
Easy and flexible installation
Compact and simplified
2.2 Advantages of the Plan
The working voltage of HLK-DL04A is 12V DC, and it can support up to 20A current output depending on the motor model and propeller model. Peak power the power consumption can reach up to 240W. The factory comes with heat sinks, which can work stably and continuously under 12V/10A power consumption. Power consumption above 12V/10A can be easily increased modify the heat dissipation scheme by adding heat sinks. High cost-effectiveness
3. Application
model aircraft
fan
Automotive Turbine
fan
4. Pin Introduction
