  4. DC DC 2W
  5. HLK-Link DC-DC Isolated Power Module B0505XT-2WR3, B0509/B0512/B0515/B0524XT-2WR3,B1205XT-2WR3 ,B2405XT-2WR3,Unregulated
    $1.26
BxxXT-2WR3-1
  • Sustainable short circuit protection
  • Isolated voltage 1500VDC
  • No-load input current as low as 3mA
  • Working environment temperature: -40℃ ~ +85℃
  • Efficiency up to 89%
  • International standard pin mode
  • Small SMD package
ItemsWorking conditionsMin.Typ.Max.Unit
Input current(fully loaded/unloaded)3.3VDC Input--740/8--mA
5VDC Input --477/8--
12VDC Input --196/8--
15VDC Input --161/8--
24VDC Input--98/8--
Reflected Ripple Current
--15--mA
Impulse voltage  (Isec.max)3.3VDC Input-0.7--5VDC
5VDC Input -0.7--9
12VDC Input -0.7--18
15VDC Input -0.7--20
24VDC Input -0.7--30
Capacitive filtering
Hot plug
Not available
ItemsWorking and testing conditionsMin.Typ.Max.Unit
Output Voltage AccuracyRefer to Error Envelope Curve
--±15.0%
Linear adjustment rateinput voltage variation3.3V output--
--±1.5%
others----±1.2%
Load Regulation10%~100% load3.3VDC--
12
20%
5VDC--815%
9VDC--810%
12VDC--710%
15VDC--610%
24VDC--610%
Ripple & NoisePure resistive load, 20HMz bandwidth, peak-to-peak--4580mVp-p
Temperature drift coefficient
Full load----±0.03%/℃
Note: 1. The test method of ripple and noise is twisted pair test method.
