E0305S-1WR3 E0303S/E0309S/E0312S/E0315S/E0324S-1WR3 3KV isolated DC DC power converter module
Visitor44
Price$1.02
Features: constant voltage input, isolated unregulated output 1W
Isolated voltage: 3000VDC
Efficiency: up to 89%
Working environment temperature:-40°C~+85°C
Failure-free time MTBF>3.5 million hours (3500000Hrs)
Output short circuit protection: continuous short circuit protection, automatic recovery
Small SIP package, black flame retardant and heat resistant plastic housing
International standard pin method
Ripple/Noise (20MHz bandwidth): 45mVp-p (Typ.)
| Input current (full load/no load) | 3.3VDC Input Series | -- | 370/3 | --/15 | mA |
| 5VDC Input Series | -- | 235/3 | --/15 | ||
| 12VDC Input Series | -- | 99/3 | --/15 | ||
| 15VDC Input Series | -- | 99/3 | --/15 | ||
| 24VDC Input Series | -- | 51/3 | -- | ||
| Reflection ripple current | -- | 15 | -- | mA | |
| Impulse voltage(Isec.max) | 3.3VDC Input Series | -0.7 | -- | 5 | VDC |
| 12VDC Input Series | -0.7 | -- | 18 | ||
| 15VDC Input Series | -0.7 | -- | 21 | ||
| Hot plug | Non-support | ||||
| Output Voltage Accuracy | See Error Envelope Curve | -- | -- | ±15.0 | % | |
| Linear adjustment rate | Input voltage variation ±1% | 3.3V Input | -- | -- | ±1.5 | % |
| others | -- | -- | ±1.2 | % | ||
| Load regulation | 10%~100% load | 3.3VDC Output | -- | 10 | -- | % |
| 5VDC Output | -- | 8 | -- | % | ||
| 9VDC Output | -- | 8 | -- | % | ||
| 12VDC Output | -- | 7 | -- | % | ||
| 15VDC Output | -- | 6 | -- | % | ||
| 24VDC Output | -- | 6 | -- | % | ||
| Ripple & Noise | Pure resistive load, 20HMz bandwidth, peak-to-peak | -- | 45 | 100 | mVp-p | |
| Notes: ①The test method of ripple and noise is twisted pair test method. | ||||||
