  4. DC DC 6W
  5. URA2405YMD-6WR3 dc dc step down converter module power module URA2412/15/24YMD-6W stabilized dual output input (4:1 )
    $3.87
URA24_YMD-6WR3-1
3. Ultra-long standby power consumption 0.036W(Typle)
4. Quick Start:1mS(Typ)
6. Metal case, low output ripple
Storage temperture-40—+125 ℃℃
Ripple & Noise50/80(max)
Mvp-p
ItemWorking conditions
Min.Typ.Max.Unit
Input currency( full loaded/ Unloaded24VDC Input Series3.3V-235/1241/2mA
others-284/1301/2
48VDC Input Series3.3V-118/0.5121/1
others-147/0.5151/1
110VDC Input Series3.3V-51/0.353/0.5
others-64/0.366/0.5
Reflected ripple current24VDC Input Series--40--
48VDC Input Series--30--
110VDC Input Series--20--
Impulse voltage
(Isec.max)
24VDC Input Series-0.7--50
48VDC Input Series-0.7--100
110VDC Input Series-0.7--200
Start voltage24VDC nominal input series, nominal input voltage--9
-±1.0%±2.0%-±2.0%±3.0%
±2.0%±0.5%-±1.5%±2.0%
Load adjustment rate
20%~100% rate
load, balanced
±0.5%
±1.0%-±4.0%±5.0%
