  3. Communication Module
  4. WiFi Router Module
  5. WiFi6 OpenWrt AX3000 IPQ5018+QCA8337+QCN6102 Gigabit ports* 5 UART Gigabit Router WiFi Module 2.4G/5.8G Dual-frequency HLK-RM68
    $30.88
Download Files
HLK-RM68: https://drive.google.com/drive/folders/1cPfJ_ET9kue43kTUIWVMKmQjL_faICfI?usp=sharing
Introduction
HLK-RM68 is a high-performance embedded WIFI6AX3000 module launched by Hi-link Electronics. It is a highly integrated system-on-chip wireless network router module. It uses the IPQ5018+QCA8337+QCN6102 solution with a theoretical maximum wireless rate of 574Mbps+2402Mbps. It has 4 external power amplifier FEMs and is designed and built for high-performance, low-power, and cost-effective wireless network applications, including home routers, mesh nodes, and gateways.
The SoC used consists of a 1GHz 64-bit dual-core ARMCortexA53 processor and an advanced 12-thread programmable network processor, which completely unloads Wi-Fi processing and can provide nearly 100% CPU margin for customer applications.
The IPQ5018 SoC includes a 2x22.4GHz802.11axWi-Fi subsystem, combined with the RF chip QCN61022x2/160MHz11ax, and also includes a variety of peripherals, including SGMII and USB3.0 (host) ports. It can provide dual-band concurrent chipset solutions for the WIFI6AX3000 wireless router platform.
Featrures
  • Dual-band (2.4GHz and 5GHz) MIMO802.11a/b/g/n/ac/ax RF, bandwidth 20/40/80/160MHz
  • GbFlash/2Gb DDR3;
  • Bandwidth range: 2.4-2.4835GHz5.180-5.885GHz;
  • Integrated 2.4GHz/5GHz FEM;
  • Wireless connection method: I-pex first generation socket*4;
  • Interface WAN.LAN1.LAN2.LAN3.LAN4.LAN5.USB3.0.PCIE;
  • WAN access method PPPoE, dynamic IP, static IP, 3G/4G/5G;
  • Static address allocation, virtual server, port forwarding DMZ host;
  • Module power supply voltage: DC5V3.5A;
Module specificial
RM68-2 拷贝
Technical specifications
ModuleModelHLK-RM68
Wireless parametersWireless standardMIMOIEEE802.11a/b/g/n/ac/ax
Frequency range2.4-2.4835GHz5.180-5.825GHz
Transmission power802.11b:+23±2dBm(11M) @EVM:-30dB802.11a:+21±2dBm(54M) @EVM:-35dB
802.11g:+22±±2dBm(54M) @EVM:-30dB802.11n(20M):+20±2dBm(MCS7) @EVM:-41dB
802.11n(20M):+22±2dBm(MCS7) @EVM:-33dB802.11n(40M):+20±2dBm(MCS7) @EVM:-41dB
802.11n(40M):+22±2dBm(MCS7) @EVM:-33dB801.11ac(20M):+19±2dBm(MCS9) @EVM:-43dB
801.11ac(20M):+22±2dBm(MCS9) @EVM:-39dB801.11ac(40M):+19±2dBm(MCS9) @EVM:-43dB
801.11ac:(40M)+21±2dBm(MCS9) @EVM:-38dB801.11ac(80M):+19±2dBm(MCS9) @EVM:-44dB
802.11ax(20M):+21±2dBm(MCS11) @EVM:-40dB802.11ax(20M):+19±2dBm(MCS11) @EVM:-43dB
802.11ax(40M):+21±2dBm(MCS11) @EVM:-39dB802.11ax(40M):+19±2dBm(MCS11) @EVM:-42dB
802.11ax(80M):+19±2dBm(MCS11) @EVM:-40dB
802.11ax(160M):+19±2dBm(MCS11) @EVM:-40dB
Unit:dBmch1ch6ch13Unit:dBmch50ch114ch163
2GHT20:(MCS0)-94.5-94.5-94.55GHT20:(MCS0)-94.0-94.0-94.0
Receiving sensitivity2GVHT20:(MCS9)-69.0-69.5-69.05GVHT40:(MCS9)-66.0-66.0-65.5
2GHE20:(MCS11)-63.5-63.5-63.55GHE80:(MCS11)-59.5-59.5-59.5
2GHT40:(MCS0)-91.5-91.5-91.55GVHT160:(MCS0)-83.5-83.5-83.5
2GVHT40:(MCS9)-68.0-68.0-68.05GHE160:(MCS9)-60.5-60.5-60.5
2GHE40:(MCS11)-62.5-62.5-62.55GHE160:(MCS11)-55.0-55.0-55.0
Antennal form
External: I-PEX first generation antenna base * 5
Hardware parametersSotrage capacityDDR3:256M(2Gbit);NandFlash:128M(1Gbit)
ChipIPQ5018+QCA8337+QCN6102
Hardware portsUART,GPIO,SPI,USB,PWM,IIC
Networkportsgigabit port*6: WAN*1、LAN*5
USBPartial pin reuseUSB3.0
PCIE
PCIE2.0*1
Working voltage5V
Working current
Continuous transmission => Average: 1.5A@5V (it is recommended that the 5V power supply capacity should reach 3.5A or more)
Normal mode => Average: 0.9A@5V
IO drive capabilityVMax:12ma
TemperatureWorking temperature: -20℃~80℃
Pcakge60*90mm
Storage environmentTemperature: -40~+85℃, relative humidity: 5%-90%RH (non-condensing)
Software parametersWireless network typeSTA/AP/APClient
firmware upgradeWeb page upgrade, command network port upgrade
Network protocol
IPv4, TCP/UDP
Software environmentOpenwrt
User configurationWeb page configuration
Module pic
