  3. Communication Module
  4. IOT WiFi Module
  5. Hilink WiFi6 Serial Port Module BLE5.4 Bluetooth Dual-band Low Power High Speed Data Transparent Serial Communication B300
    $2.60
B300-2
HLK-B300 is a low-cost embedded UART-WIFI (serial wireless network) module launched by Hailingke Electronics. It is a Wi-Fi6+BLE combination chipset used for low-power and high-performance application development.
This product is based on an embedded module that complies with network standards through a serial interface, embedded with a TCP/IP protocol stack, and capable of converting between user serial ports and wireless networks (WIFI/BLE).
Through the HLK-B300 module, traditional serial devices can transmit their data over the Internet network without changing any configuration, providing a complete and fast solution for users' serial devices to transmit data over the network.
Product Characteristics
  • The system includes 20MHz and 40MHz 2.4G/5.8G radios, Wi Fi 802.11a/b/g/n/ax, and BLE5.4 baseband
  • ArmV8-M core, clock speed: 160MHz
  • Built in 512KB RAM, 4M embedded Flash memory
  • The working voltage supports 2.1-3.63V, with a typical value of 3.3V
  • BLE assists in achieving fast Wi Fi distribution network
  • Supports AP/STA and BLE coexistence modes, with WiFi security support for WPA/WPA2/WPA3
  • Peripheral interface, 2 * UART, 9 * GPIO,
  • Widely used in the Internet of Things
Performance and electrical parameters
ModuleModelHLK-B300
PackageDirect insertion
Wireless parametersWireless standard
IEEE802.11a/b/g/n/ax
 BLE:support BLE5.4
Frequency range2.412GHz-2.484GHz     4.900GHz-5.925GHz
Transmit power11g-54Mbps:19dBm 11g-54Mbps:14dBm
11n-MCS0:18dBm 11n-MCS0: 18dBm
11ax-MCS0:19dBm 11ax-MCS0:16dBm
Receiver Sensitivity11g-54Mbps:-75dBm 11g-54Mbps:-76dBm
11n-MCS0:-92 dBm 11n-MCS0:-90dBm
11ax-MCS0:-92dBm 11ax-MCS0:-91dBm
Antenna formExternal: I-PEX connector
Built in: Surface mount antenna
Bluetooth parametersFrequency range2402~2480MHz
Output power0~15dBm   Typical value: 9dBm
Receiver Sensitivity-97dBm
Hardware parameters
Hardware interface2*UART,9*GPIO
Operation voltageDC2.1~3.63V  Typical value:3.3V
GPIO driver capacityMax:12.8mA
Operation current requirement≥500mA
Peak current of module
300mA
No load operating current70mA
Operating Temperature-40℃~85℃
Serial port transparent transmissionTransmission rate9600-921600bps
TCP Client1
Software parametersWireless network typeSTA/AP
Safety mechanismWPS/WEP/WPA/WPA2 Personal/WPA2 Enterprise/WPA3
Encryption typeWEP64/WEP128/TKIP/AES
Network protocolIPv4, TCP/UDP,Lwip
User ConfigurationAT+instruction set
Pin introduction
PinInternet nameTypeDescription
1RSTIChip enabled, high efficiency, low level reset
2IO5I/ORetain
3IO2I/ORetain
4IO11I/ORetain
5IO12I/O
ES0 button, enter at command mode/factory reset, please pull up if not in use
6IO14I/ORetain
7IO17I/ORetain
8VCCP3.3V power
9GNDPGND
10NCI/ORetain
11NCI/ORetain
12IO20I/ORetain
13IO21I/O
WiFi connection status
0: WiFi not connected
1: WiFi is connected
14IO22I/O
TCP connection status
0: Not connected to TCP server
1: Connected to TCP server
15GNDPGND
16IO0I/OModule status indicator light
17IO8I/OThe indicator light is not currently in use
18IO1I/ORetain
19IO3I/ODebugging serial port (RX pin)
20IO4I/ODebugging serial port (TX pin)
21RXDI/OMain serial port receiving pin
22TXDI/OMain serial port transmit pin
1
