Visitor4461
Price$1.98
Global universal input voltage(85-305VAC)
| Altitude | ≤2000 m |
| Input vlotage range | 85-305VAC/100-430VDC |
| Input low start | ≤50mS |
Output Features(3.3V/3000mA)
| No-load rated output voltage | 3.3±0.1Vdc |
| Full-load rated output voltage | 3.3±0.1Vdc |
| Short term maximum output current | ≥3850mA |
| Rated output current | 3000mA |
| Voltage regulation rate | ±0.1% |
Output Features(5V/3000mA)
| No-load rated output voltage | 5±0.1Vdc |
| Full-load rated output voltage | 5±0.1Vdc |
| Short term maximum output current | ≥3500mA |
Output Features(9V/1660mA)
| No-load rated output voltage | 9±0.3Vdc |
| Full-load rated output voltage | 9±0.3Vdc |
| Short term maximum output current | ≥2000mA |
| Rated output current | 1660mA |
Output Features(12V/1250mA)
| No-load rated output voltage | 12±0.2Vdc |
| Full-load rated output voltage | 12±0.2Vdc |
| Short term maximum output current | ≥1440mA |
| Rated output current | 1250mA |
Output Features(15V/1000mA)
| No-load rated output voltage | 15±0.2Vdc |
| Short term maximum output current | ≥1240mA |
Output Features(24V/625mA)
| No-load rated output voltage | 24±0.2Vdc |
| Full-load rated output voltage | 24±0.2Vdc |
| Short term maximum output current | ≥750mA |
| Rated output current | 620mA |
