Visitor1712
Price$6.18
HLK-LD2453: https://drive.google.com/drive/folders/19mnex5a37qAD-inONMiodeao2Xn7rPWe
1. Product Overview
Target tracking refers to real-time tracking of the location of a target within an area, achieving distance measurement, angle measurement, and speed measurement of the target.
HLK-LD2453 is a high-precision multi-target recognition sensor, which is mainly used in ordinary applications such as homes, offices, and hotels indoor scene, achieving positioning and tracking of multiple human bodies.
The sensor hardware consists of AIoT millimeter wave radar chips, high-performance one transmitter two receiver microstrip antennas, low-cost MCUs, and peripheral auxiliary components
Composition of auxiliary circuits. The intelligent algorithm firmware adopts advanced signal processing technology proprietary to FMCW waveform and millimeter wave radar chips.
2. Product Features
24GHz ISM frequency band
Integrate intelligent millimeter wave radar single-chip and intelligent algorithm firmware
Accurate target positioning and tracking
Ultra small module size
HLK-LD2453 size: 7mmX30mm
Environmental temperature: -20 ℃~70 ℃
3.3V power supply
Maximum detection range: 8m
Azimuth angle ± 45 °, pitch angle ± 30 °
Wall mounted installation
Maximum detection of 3 targets
3. HLK-LD2453 Specification Parameters
| Parameters | Remark | Min | Typ | Max | Unit |
| Hardware specification | |||||
| Support frequency | 24 | - | 24.25 | GHz | |
| Support maximum sweep bandwidth | - | 0.25 | - | GHz | |
| Power supply voltage | 3.0 | 3.3 | 3.6 | V | |
| Size | - | 7*30 | * | mm*mm | |
| Ambient temperature | -20 | - | 70 | °C | |
| Software specification | |||||
| Maximum sensing distance | - | 8 | - | m | |
| Range resolution | - | 0.72 | - | m | |
| Ranging accuracy | - | 0.15 | - | m | |
| Angular Accuracy | 2 | 20 | ° | ||
| Operating frequency band | Compliant with FCC/CE/non commission certification | 24 | 24.25 | GHz | |
| Sweep frequency width | - | 0.21 | - | GHz | |
| Data refresh rate | Frequency of radar reporting results | - | 10 | - | Hz |
| Average working current | - | 76 | - | mA | |
