B1505LS/B1512LS/B1503LS/B1509LS/B1515LS/B1524LS-1WR3 DC to DC 1W step down power converter module
Visitor728
Price$0.62
2. isolation voltage≤1500VDC
4. Low ripple, low noise
| Items | Working conditions | Min. | Typ. | Max. | Unit |
Input current (fully loaded/ unloaded) | 3.3VDC Input | -- | 378/6 | --/12 | mA |
| 5VDC Input | -- | 224/5 | --/10 | ||
| 12VDC Input | -- | 93/3 | --/5 | ||
| 15VDC Input | -- | 74/2 | --/4 | ||
| 24VDC Input | -- | 47/1 | --/2 | ||
| Reflected Ripple Current | 4.5 | -- | 15 | -- | mA |
| Impulse voltage (Isec.max) | 3.3VDC Input | -0.7 | -- | 5 | VDC |
| 5VDC Input | -0.7 | -- | 9 | ||
| 12VDC Input | -0.7 | -- | 18 | ||
| 15VDC Input | -0.7 | -- | 21 | ||
| 24VDC Input | -0.7 | -- | 30 | ||
| Input filter type | Capacitive filtering | ||||
| Hot plug | Not available | ||||
Output Characteristics(15v/±34mA)
| Items | Working and test conditions | Min. | Typ. | Max. | Unit | |
| Output load | Load percentage | 10 | -- | 100 | % | |
| Output VoltageAccuracy | Refer to Error Envelope Curve | -- | -- | ±15.0 | % | |
| Linear adjustment rate | Input voltage variation ±1% | 3.3V Output | -- | -- | ±1.5 | % |
| Others | -- | -- | ±1.2 | % | ||
| Load Regulation | 10%~100% Load | 3.3VDC Output | -- | 18 | 12 | % |
| 5VDC Output | -- | 12 | % | |||
| 9VDC Output | -- | 8 | % | |||
| 12VDC Output | -- | 7 | % | |||
| 15VDC Output | -- | 6 | % | |||
| 24VDC Output | -- | 5 | % | |||
| Ripple & Noise | Pure resistive load, 20MHz bandwidth, peak-to-peak | -- | 30 | 80 | mVp-p | |
| Temperature Drift Coefficient | Full load | -- | -- | ±0.03 | %/°C | |
| Note: ①The test method of ripple and noise is twisted pair test method. | ||||||
1. General application:
