Visitor670
Price$1.06
1. characteristic:Constant voltage input, isolated non stabilized voltage single output,3W
2. Isolation voltage 3000VDC
3. Transfer efficiency up to 89%
7. Small SIP package
9. High reliability and long life design,continuous working time MTBF≥3.5 million hours (3500000Hrs)
General characteristic
| Ripple & Noise | 30/80(max) | Mvp-p |
| Input current (full load/no load) | 3.3VDC Input Series | -- | 370/3 | --/15 | m'A |
| 5VDC Input Series | -- | 235/3 | --/15 | ||
| 12VDC Input Series | -- | 99/3 | --/15 | ||
| 15VDC Input Series | -- | 99/3 | --/15 | ||
| 24VDC Input Series | -- | 51/3 | -- | ||
| Impulse voltage | 3.3VDC Input Series | -0.7 | -- | 5 | VDC |
| 12VDC Input Series | -0.7 | -- | 18 | ||
| 15VDC Input Series | -0.7 | -- | 21 | ||
| Output Voltage Accuracy | See Error Envelope Curve | -- | -- | ±15.0 | % | |
| Linear adjustment rate | Input voltage variation ±1% | 3.3V Input | -- | -- | ±1.5 | % |
| others | -- | -- | ±1.2 | % | ||
| Load adjustment rate | 10%~100% load | 3.3VDC Output | -- | 10 | -- | % |
| 5VDC Output | -- | 8 | -- | % | ||
| 9VDC Output | -- | 8 | -- | % | ||
| 12VDC Output | -- | 7 | -- | % | ||
| 15VDC Output | -- | 6 | -- | % | ||
| 24VDC Output | -- | 6 | -- | % | ||
| Ripple & Noise | Pure resistive load, 20HMz bandwidth, peak-to-peak | -- | 45 | 100 | mVp-p | |
| Output short circuit protection | Continuous short circuit protection, automatic recovery | -- | ||||
