  4. 150W brick power module
  5. Hi-link DCDC half brick isolated power module 200MQ110S24 110V to 24V stabilized single circuit 200W
    $46.89
HLK-200MQ110S24-1
66V input voltage, full load output----4A
----10mA
Input surge voltage (1sec. max.)Out-of-range input will cause permanent damage-0.7--185VDC
----66
----64
--±0.1±0.2
--±0.1±0.2
Ripple&Noise20MHz bandwidth, external capaciry ≥220μF--150240mVp-p
-20--+10%
----105%
125--140V
9
--12.5A
Insulation resistanceInput-outputInsulation voltage 500VDC----100MΩ
--250--KHz
----150K hours
