  4. 300W brick power module
  5. Hi-link DCDC Half Brick Power Module 24V to 28V Isolated and Stabilized Single Circuit 300W HLK-300MH24S28A
    $61.06
300MH24S28A product list-3 拷贝
300V input voltage, full load output----28A
----30mA
Input surge voltage (1sec. max.)Out-of-range input will cause permanent damage-0.7--60VDC
----10
Input under-voltage protectionNo-load test----9
--±0.2±0.5
--±0.2±0.5
Transient Recovery Time25% load step change (step rate 1A/50uS)--100300uS
Ripple&Noise20MHz bandwidth, external capaciry ≥220μF--200280mVp-p
-20--+10%
125--140V
11.5
--15.5A
--460--KHz
dimension 拷贝
