  4. 300W brick power module
  5. Hi-link DCDC Half Brick Power Module 24V to 12V Isolated and Stabilized Single Circuit 300W HLK-300MH24S12A
    $61.08
300MH24S12A product list-3 拷贝
300V input voltage, full load output----30A
----30mA
Input surge voltage (1sec. max.)Out-of-range input will cause permanent damage-0.7--50VDC
----9
Input under-voltage protectionNo-load test----8.5
--±0.2±0.5
--±0.2±0.5
Ripple&Noise20MHz bandwidth, external capaciry ≥220μF--100120mVp-p
-10--+10%
125--150V
27.5
--35A
--200--KHz
dimension 拷贝
