  4. RS485 Series
  5. Hi-link Single Hhigh-speed Isolation Transceiver RSM485ECHT Industrial Grade RS485 Signal Isolation Module
    $1.46
RS485 product list-3 拷贝
  • Single input power supply
  • Non isolated output power pin
  • Baud rate up to 500kbps
  • Up to 256 nodes can be connected
  • Electromagnetic radiation EMI is extremely low, and electromagnetic anti-interference EMS is high
  • Working temperature range: -40 ° C~+85 ° C
  • Integrated power isolation, signal isolation, and bus ESD protection functions
Product Description
RSM(3)485ECHT/RSM485ECHT, The main function will be to convert logical levels into differential levels of RS-485 protocol, achieving signal isolation; It is an RS-485 protocol transceiver module that uses IC integration technology to achieve power isolation, signal isolation, RS-485 communication, and bus protection. The product comes with a constant voltage isolation power supply, which can achieve 2500VDC electrical isolation. The product can be easily embedded into user devices, enabling them to easily connect to RS-485 protocol networks.
Product Application  Area
Industrial communication, coal mining industry, power monitoring, communication between PLC and frequency converter, petrochemical industry, building automation ..
Product Parameters
Maximum limit parameter
Warmly  note: Using beyond the following limit values may cause permanent and irreparable damage to the module.
ProjectConditionMin
International scale valueMaxUnit
Input voltage range3.3VDC Input Series-0.73.35Vdc
5VDC Input Series-0.757
Pin soldering temperature resistanceManual welding point distance from shell 1.5mm 3-5 seconds-370
Wave soldering @ 5-10 seconds-265-
hot-swapping---Non-support
Note: This series of modules does not have input anti reverse connection function. It is strictly prohibited to input positive and negative connections in reverse, otherwise it will cause irreversible damage to the module.
ProjectSymbolConditionMinISVMaxUnit
Input voltage
VacRSM3485ECHT3.153.33.45Vdc
RSM485ECHT4.7555.25
TXD logic levelHigh levelVih
0.7Vcc--Vcc+0.5
low levelVil
0--0.3Vcc
RXD logic levelHigh levelVohIxp=-1.5mAVcc-0.4Vcc-0.2--
low levelVollo=1.5mA--
0.20.4
CON control levelHigh levelVcon-hRSM3485ECHT2.3--Vcc+0.5
RSM3485ECHT3.8--Vcc+0.5
low levelVcon-l
0--0.3Vcc
TXD driving current
Itxd
2----mA
CON driving current
Icon
5----
RXD output current
Irxd
TXD pull-up resistor
Rtxd
------KΩ
Serial interfaceRSM3485ECHT3.3V standard UART interface
RSM485ECHT5V standard UART interface
Output Features
MinISVMaxUnit
Built in isolated output power supply voltageVoRated input voltage ------Vdc
Differential output voltage (A-B)
Voo
Nominal input voltage, differential
 load of 54 Ω
1.5--Vo
Differential output current (A-B)Loo
28----mA
Bus interface protection
                                ESD electrostatic protection
RS485 dimension 拷贝
