  4. 300W brick power module
  5. Hi-link DC DC half brick power module HLK-300MH540S24 540V to 24V isolated and stabilized single circuit 300W
    $113.50
HLK-300MH540S24-1
300V input voltage,  full load output ----1.5A
----15mA
Input surge voltage (1sec. max.)Out-of-range input will cause permanent damage-0.7--1000VDC
----300
----270
--±0.2±0.5
--±0.2±0.5
Ripple&Noise20MHz bandwidth, external capaciry ≥220μF--200240mVp-p
-10--+10%
27.6--32V
13.7--17.5A
--230--KHz
