  4. 300W brick power module
  5. Hi-link DC DC half brick power module HLK-300MH540S12 540V to 12V isolated and stabilized single circuit 300W
    $113.50
HLK-300MH540S12-1
300V input voltage,  full load output ----1.5A
----15mA
Input surge voltage (1sec. max.)Out-of-range input will cause permanent damage-0.7--1000VDC
----300
----270
--±0.2±0.5
--±0.2±0.5
Ripple&Noise20MHz bandwidth, external capaciry ≥220μF--100120mVp-p
-10--+10%
14--16V
28--35A
--230--KHz
