  4. DC DC 3W
  5. DCDC isolated power module B2405M-3WR3 B2403M/B2412M/B2409M/B2415M/B2424M-3WR3 short circuit protection
    $0.96
B12_M-3WR3-1
1. characteristic:Constant voltage input, isolated non stabilized voltage single output,3W
2. Isolation voltage 1500VDC/i min,3000VDC/1s
3. Low no-load power consumption 0.14W(Typ.)
4. Transfer efficiency up to 86%
General characteristic
Storage temperture-40—+125 ℃℃
Ripple & Noise30/80(max)Mvp-p
Input current (full load/no load)5VDC Input Series--740/15--/20m'A
9VDC Input Series--416/10--/15
12VDC Input Series--308/5--/15
15VDC Input Series--247/4--/12
24VDC Input Series--154/2--/8
Reflection ripple current
--15--m'A
Impulse voltage3.3VDC Input Series-0.7--5VDC
5VDC Input Series-0.7--9
9VDC Input Series-0.7--9
12VDC Input Series-0.7--18
15VDC Input Series-0.7--20
24VDC Input Series-0.7--30
Output Voltage AccuracySee Error Envelope Curve----±15.0%
Linear adjustment rateInput voltage variation ±1%3.3V Input----±1.5%
others----±1.2%
Load adjustment rate10%~100% load3.3VDC Output--18--%
5VDC Output--12--%
9VDC Output--8--%
12VDC Output--7--%
15VDC Output--6--%
24VDC Output--5--%
----±0.03%/℃
