  4. DC DC 2W
  5. DCDC isolated power module B1212M-2WR3 B1203M/B1205M/B1209M/B1215M/B1224M-2WR3 short circuit protection
    $0.73
2. Isolation voltage 1500VDC/i min,3000VDC/1s
4. Transfer efficiency up to 91%
General characteristic
Storage temperture-40—+125 ℃℃
Ripple & Noise30/80(max)Mvp-p
Input current (full load/no load)3.3VDC Input Series--756/8--/15m'A
5VDC Input Series--454/5--/10
12VDC Input Series--186/2--/5
15VDC Input Series--148/2--/4
24VDC Input Series--92/1--/2
Reflection ripple current
--15--m'A
Impulse voltage3.3VDC Input Series-0.7--5VDC
5VDC Input Series-0.7--9
12VDC Input Series-0.7--16
15VDC Input Series-0.7--20
24VDC Input Series-0.7--30
Output Voltage AccuracySee Error Envelope Curve----±15.0%
Linear adjustment rateInput voltage variation ±1%3.3V Input----±1.5%
others----±1.2%
Load adjustment rate10%~100% load3.3VDC Output--1520%
5VDC Output--1015%
9VDC Output--810%
12VDC Output--710%
15VDC Output--610%
24VDC Output--510%
----±0.03%/℃
1、The above is only a list of typical products. If you need products beyond the list, please con
