  4. 300W brick power module
  5. Hi-link DCDC Half Brick Power Module 110V to 12V Isolated and Stabilized Single Circuit 300W HLK-300MH110S12A
    $57.98
300MH110S12A product list-3 拷贝
300V input voltage, full load output----7A
----15mA
Input surge voltage (1sec. max.)Out-of-range input will cause permanent damage-0.7--185VDC
----43
Input under-voltage protectionNo-load test----42
--±0.1±0.2
--±0.2±0.5
Ripple&Noise20MHz bandwidth, external capaciry ≥220μF--80120mVp-p
-10--+10%
125--140V
27.5
--35A
--500--KHz
dimension 拷贝
