1500W AC/DC switching power supply 36V output high power DC adjustable constant voltage and constant current HLK-1500QYL36
Visitor999
Price$70.60
HLK-1500QYL36 is a 1.5KW single output chassis type AC to DC/DC to DC power supply. The input voltage range of the entire series is 180-264VAC/250-370VDC, and it can provide DC output that can meet most industrial needs. Each model can be cooled by an internal speed controlled fan, with a working temperature of up to 60 ℃. Built in multiple functions such as adjustable output voltage and current, remote on/off control, auxiliary power supply, etc. provide various design flexibility
HLK-1500QYL12 | 277*155*70mm (L*W*H) | 1500W | 12V | 0~125A | |
HLK-1500QYL24 | 24V | 0~62.5A | |||
HLK-1500QYL36 | 36V | 0~41.6A | |||
HLK-1500QYL48 | 48V | 0~31.2A | |||
HLK-1500QYL72 | 72V | 0~20.8A | |||
HLK-1500QYL96 | 96V | 0~15.6A | |||
HLK-1500QYL110 | 110V | 0~13.6A | |||
HLK-1500QYL150 | 150V | 0~10A | |||
HLK-1500QYL220 | 220V | 0~6.8A |
Laser related machines
UV curing equipment
Charging equipment
Aging equipment
Altitude | ≤2000 | m | |
AC current | < 13A | A | |
Project name | HLK-1500QYL12 | HLK-1500QYL24 | HLK-1500QYL36 | HLK-1500QYL48 | HLK-1500QYL72 | Unit |
Rated current | 125A | 62.5A | 41.6A | 31.2A | 20.8A | A |
Current range | 0~125A | 0~62.5A | 0~41.6A | 0~31.2A | 0~20.8A | A |
Project name | HLK-1500QYL96 | HLK-1500QYL110 | HLK-1500QYL150 | HLK-1500QYL220 | Unit | |
Rated current | 15.6A | 13.6A | 10A | 6.8A | A | |
Current range | 0~15.6A | 0~13.6A | 0~10A | 0~6.8A | A | |
Project name | Unit | |
