1200W AC/DC switching power supply 150V output high power DC adjustable constant voltage and constant current HLK-1200QYL150
Visitor1010
Price$46.50
HLK-1200QYL series is a 1.2KW single output chassis type AC to DC/DC to DC power supply. The input voltage range of the entire series is 180-264VAC/250-370VDC, and it can provide DC output that can meet most industrial needs. Each model can be cooled by an internal speed controlled fan, with a working temperature of up to 60 ℃. Built in multiple functions such as adjustable output voltage and current, remote on/off control, auxiliary power supply, etc. provide various design flexibility
| HLK-1200QYL12 | 237*130*65 | 1200W | 36V | 0~100A | |
HLK-1200QYL24 | 48V | 0~50A | |||
HLK-1200QYL36 | 36V | 0~33.3A | |||
HLK-1200QYL48 | 48V | 0~25A | |||
HLK-1200QYL72 | 72V | 0~16.7A | |||
HLK-1200QYL96 | 96V | 0~12.5A | |||
HLK-1200QYL110 | 110V | 0~10.9A | |||
HLK-1200QYL150 | 150V | 0~8A | |||
HLK-1200QYL220 | 220V | 0~5.5A |
Laser related machines
UV curing equipment
Charging equipment
Aging equipment
Altitude | ≤2000 | m | |
AC current | < 13A | A | |
Project name | HLK-1200QYL12 | HLK-1200QYL24 | HLK-1200QYL36 | HLK-1200QYL48 | HLK-1200QYL72 | Unit |
Rated current | 100A | 50A | 33.3A | 25A | 16.7A | A |
Current range | 0~100A | 0~50A | 0~33.3A | 0~25A | 0~16.7A | A |
Project name | HLK-1200QYL96 | HLK-1200QYL110 | HLK-1200QYL150 | HLK-1200QYL220 | Unit | |
Rated current | 12.5A | 10.9A | 8A | 5.5A | A | |
Current range | 0~12.5A | 0~10.9A | 0~8A | 0~5.5A | A | |
Project name | Unit | |
