  4. DC DC 2W
  5. IB1212S-2WR3 IB1203/IB1209/IB1205/IB1224S-2W Hi-link DC-DC isolated power supply module with short-circuit protection
    $1.05
IB_S-2WR3 Series Mode list 拷贝
IB12_S-2WR3-2 拷贝 2
Product Features:
  • 7PinSIP international standard pin
  • Isolation voltage: 1500VDC
  • Low static current and high conversion efficiency
  • Low ripple coefficient and low noise
  • Working environment temperature: -40 ℃~+85 ℃
  • MTBF ≥ 3.5 million hours (3500000 Hrs)
  • Output short circuit protection: sustainable short circuit protection, automatic recovery
  • Built in soft start technology
  • Special specification products can be designed according to customer needs
Input characteristic:
Item
Working ConditionsMin.Typ.Max.Unit
Input voltage range5VDC input series4.7555.25Vdc
12VDC input series10.81213.2
24VDC input series22.82425.2
Max output power
----2W
Input fliter typle
Capacitive filtering
Hot plug
*This series of modules does not have input anti reverse connection function. It is strictly prohibited to input positive and negative reverse connections, otherwise it will cause irreversible damage to the module
Output characteristic:
ItemWorking and testing conditionMin.Typ.Max.Unit
Output Voltage AccuracySee Error Envelope Curve----±1%
Linear adjustment rateInput voltage variation ±5%----±0.5%
Load adjustment rate10%~100% load--+1+2%
Ripple & NoisePure resistive load, 20HMz bandwidth, peak-to-peak--30--mVp-p
----±0.03%/℃
Output short circuit protectionContinuous short circuit protection, automatic recovery--
General characteristic:
Item
Working conditionMin.Typ.Max.Unit
Insulation voltageInput output, test time of 1 minute, leakage current less than 1mA1500----VDC
Insulation resistance Input output, insulation voltage 500VDC 1000-M Ω1000----MΩ
Isolation capacitorInput output, 100KHz/0.1V --40-- pF--40--pF
Working temperature Use reference temperature derating curve chart-40--+85
Storage temperature
-40--+125
Temperature rise of the casing during operation
--25--
Storage humidityNo condensation5--95%RH
Pin resistance to welding temperatureWelding point distance from the shell 1.5mm, 10 seconds----+300℃
Switching frequency Full load, nominal voltage input--100300KHz
Shock
10-55Hz, 10G, 30 Min. along X, Y and Z
Shell material
Black flame retardant and heat-resistant plastic (UL94V-0)
Minimum time between failuresMIL-HDBK-217F@25℃3.5X10 6----Hrs
