Hi-link DC DC 1/4 brick power module HLK-100MQ110S05A 110V to 5V isolated and stabilized single circuit 100W
Visitor390
Price$44.70
Maximum input current | 43V input voltage, full load output | -- | -- | 2 | A |
| No-load input current | Rated input voltage | -- | 6 | 10 | mA |
| Input under-voltage protection | No-load test, Full load testing will provide overcurrent protection in advance | -- | -- | 40 | |
| Linear regulation rate | Full load, input voltage changes from low voltage to high voltage | -- | ±0.2 | ±0.2 | |
Load regulation | Nominal input voltage, ranging from 10% to 100% load | -- | ±0.2 | ±0.2 | |
| Ripple&Noise | 20MHz bandwidth, external capaciry ≥220μF | -- | 80 | 100 | mVp-p |
| Output overvoltage protection | 120 | -- | 130 | V | |
| Output overcurrent protection | 22 | -- | 28 | A | |
| Insulation resistance | Input-output | Insulation voltage 500VDC | -- | -- | 10 | MΩ |
| Switching frequency | -- | 180 | -- | KHz | ||
| Mean time between failures | -- | -- | 150 | K hours | ||
