  4. 100W brick power module
  5. Hi-link DC DC 1/4 brick power module HLK-100MQ48S05A 48V to 5V isolated and stabilized single circuit 100W
    $44.70
HLK-100MQ48S05A-1
18V input voltage,  full load output ----8A
----20mA
Input surge voltage (1sec. max.)Out-of-range input will cause permanent damage-0.7--80VDC
----18
----17
--±0.1±0.2
--±0.1±0.2
Ripple&Noise20MHz bandwidth, external capaciry ≥220μF--80100mVp-p
-20--+10%
125--140V
22
--28A
--200--KHz
