  4. 100W brick power module
  5. Hi-link DC DC 1/4 brick power module HLK-100MQ24S05A 24V to 5V isolated and stabilized single circuit 100W
    $39.26
HLK-100MQ24S05A-1
9V input voltage, Output power 60W----8A
----20mA
Input surge voltage (1sec. max.)Out-of-range input will cause permanent damage-0.7--40VDC
----9
----8.5
--±0.1±0.2
--±0.1±0.2
Ripple&Noise20MHz bandwidth, external capaciry ≥220μF--50100mVp-p
-20--+10%
----105%
125--140V
22
--28A
--160--KHz
