  4. 300W brick power module
  5. Hi-link DCDC Half Brick Power Module 110V to 15V Isolated and Stabilized Single Circuit 300W HLK-300MH110S15A
    $57.98
300MH110S15A product list-3 拷贝
300V input voltage, full load output----6A
----20mA
Input surge voltage (1sec. max.)Out-of-range input will cause permanent damage-0.7--185VDC
----43
Input under-voltage protectionNo-load test----42
--±0.1±0.2
--±0.1±0.2
Ripple&Noise20MHz bandwidth, external capaciry ≥220μF--100150mVp-p
-10--+10%
----105%
125--140V
22
--28A
--520--KHz
dimension 拷贝
