  4. 300W brick power module
  5. Hi-link DCDC Half Brick Power Module 540V to 24V Isolated and Stabilized Single Circuit 300W HLK-300MH540S24
    $108.00
300MH540S24 product list-3 拷贝
300V input voltage, full load output----1.5A
----15mA
Input surge voltage (1sec. max.)Out-of-range input will cause permanent damage-0.7--1000VDC
----300
Input under-voltage protectionNo-load test----270
--±0.2±0.5
--±0.2±0.5
Ripple&Noise20MHz bandwidth, external capaciry ≥220μF--200240mVp-p
-10--+10%
27.6--32V
13.7
--17.5A
--230--KHz
dimension 拷贝
