  4. 300W brick power module
  5. Hi-link DCDC Half Brick Power Module 540V to 12V Isolated and Stabilized Single Circuit 300W HLK-300MH540S12
    $108.00
300MH540S12 product list-3 拷贝
300V input voltage, full load output----1.5A
----15mA
Input surge voltage (1sec. max.)Out-of-range input will cause permanent damage-0.7--1000VDC
----300
Input under-voltage protectionNo-load test----270
--±0.2±0.5
--±0.2±0.5
Ripple&Noise20MHz bandwidth, external capaciry ≥220μF--100120mVp-p
-10--+10%
14--16V
28
--35A
--230--KHz
dimension 拷贝
