  4. 350W brick power module
  5. Hi-link DCDC Half Brick Power Module 24V to 48V Isolated and Stabilized Single Circuit 350W HLK-350MH24S48
    $57.98
350MH24S48 product list-3 拷贝
43V input voltage, full load output----25A
----30mA
Input surge voltage (1sec. max.)Out-of-range input will cause permanent damage-0.7--50VDC
----18
Input under-voltage protectionNo-load test----16
--±0.1±0.5
--±0.1±0.5
Ripple&Noise20MHz bandwidth, external capaciry ≥220μF--300480mVp-p
-10--+10%
125--150%
8.3
--10A
--500--KHz
dimension 拷贝
