4000W AC/DC switching power supply 110V output high power DC adjustable constant voltage and constant current HLK-4000QYL110
Visitor1007
Price$192.80
HLK-4000QYL110 is a 4KW single output chassis type AC to DC/DC to DC power supply. The input voltage range of the entire series is 180-264VAC/250-370VDC, and it can provide DC output that can meet most industrial needs. Each model can be cooled by an internal speed controlled fan, with a working temperature of up to 60 ℃. Built in multiple functions such as adjustable output voltage and current, remote on/off control, auxiliary power supply, etc. provide various design flexibility.
HLK-4000QYL12 | 300*200*70mm (L*W*H) | 4000W | 12V | 0~290A | |
HLK-4000QYL24 | 24V | 0~166.7A | |||
HLK-4000QYL36 | 36V | 0~111A | |||
HLK-4000QYL48 | 48V | 0~83.3A | |||
HLK-4000QYL72 | 72V | 0~55.6A | |||
HLK-4000QYL96 | 96V | 0~41.7A | |||
HLK-4000QYL110 | 110V | 0~36.4A | |||
HLK-4000QYL150 | 150V | 0~26.7A | |||
HLK-4000QYL220 | 220V | 0~18.2A |
Laser related machines
UV curing equipment
Charging equipment
Aging equipment
Altitude | ≤2000 | m | |
AC current | < 30A | A | |
Project name | HLK-4000QYL12 | HLK-4000QYL24 | HLK-4000QYL36 | HLK-4000QYL48 | HLK-4000QYL72 | Unit |
Rated current | 290A | 166.7A | 111A | 83.3A | 55.6A | A |
Current range | 0~290A | 0~166.7A | 0~111A | 0~83.3A | 0~55.6A | A |
Project name | HLK-4000QYL96 | HLK-4000QYL110 | HLK-4000QYL150 | HLK-4000QYL220 | Unit | |
Rated current | 41.7A | 36.4A | 26.7A | 18.2A | A | |
Current range | 0~41.7A | 0~36.4A | 0~26.7A | 0~18.2A | A | |
Project name | Unit | |
