3000W AC/DC switching power supply 12V output high power DC adjustable constant voltage and constant current HLK-3000QYL12
Visitor1030
Price$153.60
HLK-3000QYL12 is a 3KW single output chassis type AC to DC/DC to DC power supply. The input voltage range of the entire series is 180-264VAC/250-370VDC, and it can provide DC output that can meet most industrial needs. Each model can be cooled by an internal speed controlled fan, with a working temperature of up to 60 ℃. Built in multiple functions such as adjustable output voltage and current, remote on/off control, auxiliary power supply, etc. provide various design flexibility.
HLK-3000QYL12 | 285*185*70mm (L*W*H) | 3000W | 12V | 0~250A | |
HLK-3000QYL24 | 24V | 0~125A | |||
HLK-3000QYL36 | 36V | 0~83.3A | |||
HLK-3000QYL48 | 48V | 0~62.5A | |||
HLK-3000QYL72 | 72V | 0~41.7A | |||
HLK-3000QYL96 | 96V | 0~31.3A | |||
HLK-3000QYL110 | 110V | 0~27.3A | |||
HLK-3000QYL150 | 150V | 0~20A | |||
HLK-3000QYL220 | 220V | 0~13.6A |
Laser related machines
UV curing equipment
Charging equipment
Aging equipment
Altitude | ≤2000 | m | |
AC current | < 30A | A | |
Project name | HLK-3000QYL12 | HLK-3000QYL24 | HLK-3000QYL36 | HLK-3000QYL48 | HLK-3000QYL72 | Unit |
Rated current | 250A | 125A | 83.3A | 62.5A | 41.7A | A |
Current range | 0~250A | 0~125A | 0~83.3A | 0~62.5A | 0~41.7A | A |
Project name | HLK-3000QYL96 | HLK-3000QYL110 | HLK-3000QYL150 | HLK-3000QYL220 | Unit | |
Rated current | 31.3A | 27.3A | 20A | 13.6A | A | |
Current range | 0~31.3A | 0~27.3A | 0~20A | 0~13.6A | A | |
Project name | Unit | |
