  4. DC DC 0.75W
  5. DCDC Isolated Power Module IB0505S-W75R3 IB0512S-W75R3 Stabilized DC Power Single-Channel Output Short-Circuit Protection
    $0.95
IB_W75R3 Series Mode list 拷贝
1. characteristic:Constant voltage input, isolated stabilized voltage single output
2. Isolation voltage≤1500VDC
3. output short-circuit protection, self-recovery
4. Efficiency: up to 73%
5. operating temperature range :-40°C~+85°C
6. Small SIP package, plastic housing
7. International standard pin out method
8. Ripple/noise (20MHz broadband):30mVp-p(Typ.)
9. Adopts high quality environmental protection, waterproof and heat conducting adhesive for filling and sealing, moisture-proof and vibration proof, meeting the waterproof and dustproof IP65 standard
Project nameWorking conditionMinTyp.Max.Unit
Insulation voltageInput output, test time 1 minute, leakage current less than 1mA1500----VDC
Insulation resistanceInput output, insulation voltage 500VDC1000----MΩ
Isolation capacitorInput output, 100KHz/0.1V--20--pF
Working enviroment temperature
-40--+85℃
Storage temperture
-40--+125
The shell heats up during work
--25--
Relative humidityNo condensation5--95%RH
Pin soldering temperature resistanceWelding point distance from shell 1.5mm, 10 seconds----+300℃
Switching frequencyFull load, nominal voltage input--100--KHz
Vibration
0-55Hz,10G,30Min, along X,Y and Z
Shell material
Black flame retardant and heat-resistant plastic((UL94 V-0)
Min error-free interval MIL-HDBK-217K@25℃3.5*10⁶----Hrs
Input Current(full/empty load)5VDC input series3.3VDC/5VDC outpt--209/8221/--mA
9VDC/12VDC outpt--208/12221/--
12VDC input series3.3VDC  outpt--92/898/--
5VDC  outpt--87/893/--
12VDC  outpt--86/891/--
24VDC input series3.3VDC  outpt--46/851/--
5VDC  outpt
44/848/--
12VDC  outpt--43/847/--
Reflection ripple current
--15--mA
5VDC Input Series
-0.7--9
12VDC Input Series
-0.7--18
24VDC Input Series
-0.7--30
Capacitive filtering
----±3%
Linear adjustment rateInput voltage variation ±1%----±0.25%
Load adjustment rate10%~100% load--±1±2%
Ripple & NoisePure resistive load, 20HMz bandwidth, peak-to-peak--50100mVp-p
Temperature Drift CoefficientFull load----±0.03%/℃
Output short circuit protectionLong term short circuit protection, automatic recovery
①The test method of ripple and noise twisted pair test method.
Typical Application Reference Circuit( Recommended Parameters)
  1. Conventinal applications
    To further reduce the input and output ripple, a capacitor filter network can be connected to the input and output terminals, and the application circuit is shown in Figure 1.
    However, care should be taken to select the appropriate filtering capacitor. If the capacitor is too large, it is likely to cause start-up problems. For each output, under the condition of ensuring safe and reliable operation, the recommended capacitive load value is detailed in Table 1. recommended capacitive load value details (Table 1).
Recommended capacitive list 1
Vin(Vdc)Cin(uF)Vo(Vdc)Count(uF)
54.7510
122.294.7
241122.2
--151
   2. EMI typical application circuit
Recommended EMC reference circuit list 2
Vin(Vdc)5/12/24
Cin4.7uF/50V
CountRefer to list 1
Lin4.7uH
Lout4.7uH
3. Output load requirements
To ensure that the module works efficiently and reliably, the minimum output load must not be less than 10% of the rated load when in use. If the power you need is really small, please connect
a resistor in parallel between the positive and negative terminals of the output (the sum of the actual power used by the resistor is greater than or equal to 10% of the rated power and the rated power of the selected resistor must be more than 5 times the actual power used, otherwise the temperature of the resistor will be higher).
