ACDC Isolated Power Supply Module 220V to 5V/9V/12V/24V Step-Down Regulator HLK-60SR05/60SR09/60SR12/60SR24 60W
Visitor2684
Price$7.20
Ultra small and the smallest volume in the industry in terms of homogeneity
Global universal input voltage (100~240Vac)
Low power consumption, green environmental protection, no-load loss<0.21W
Low ripple, low noise
Good output short circuit and overcurrent protection with self recovery capability
Input/output isolation withstand voltage 3000Vac
100% full load aging and testing
High reliability, long-life design, continuous working time greater than 100000 hours 9
Meet UL, CCC, and CE requirements; Product design meets EMC and safety testing requirements
Adopting high-quality environmentally friendly waterproof thermal conductive adhesive for sealing, moisture-proof and vibration proof, meeting the IP65 standard for waterproof and dustproof
Economic solutions with high cost-effectiveness
Can work without external circuits
| Project name | Technical standard | Unit | Remark |
| Working Temerature | -25—+40 | ℃ | |
| Storage temperature | -40—+80 | ℃ | |
| Thermal methods | Natural cooling | ||
| Atmospheric pressure | 80—106 | Kpa | |
| Altitude | ≤2000 | m | |
| Vibration coefficient | 10~500Hz,2G10min./1cycle, 60min.each along X,Y,Z axes | Meets requirements for secondary road transportation |
| Project name | Technical requirement | Unit | Remark |
| Rated input voltage | 100-240 | Vac | |
| Input vlotage range | 85-265VAC/120-350VDC | Vdc | |
| The maximum input current | ≤1.5 | A | |
| Input inrush current | ≤60 | A | |
| Input low start | ≤100 | mS | |
| External fuse recommended | 3.15A/250Vac | Slow blow |
Output Features(5V/10000mA)
| No load rated output voltage | 5+0.2 | vdc | |
| Full-load rated output voltage | 5±0.2 | vdc | |
| Short term maximum output current | ≥10200 | mA | |
| Output current | 10000 | mA | |
| Voltage regulation | 士0.2 | % | |
| Load Regulation | 士0.5 | % | |
| Input low voltage efficiency | Vin=115Vac, Output full load>84 | % | |
| Input high voltage efficiency | Vin=230Vac,output full load>85 | % | |
Output ripple and noise (mVp-p) | ≤100 Rated input voltage, output at full load. Use a 20MHz bandwidth oscilloscope to test the load end with 47uF and 0.1uF capacitors. | mV | |
| Output over-current protection | Output 130-180% of maximum load | A | |
| Short Circuit Protection | Short circuit directly during normal output, and automatically resume normal operation after the short circuit is removed | Do not damage the entire machine |
Output Features(9V/6660mA)
| No load rated output voltage | 9+0.2 | vdc | |
| Full-load rated output voltage | 9±0.2 | vdc | |
| Short term maximum output current | ≥6860 | mA | |
| Output current | 6660 | mA | |
| Input low voltage efficiency | Vin=115Vac, Output full load>86 | % | |
| Input high voltage efficiency | Vin=230Vac,output full load>88 | % | |
504200mA)
| No load rated output voltage | 12+0.2 | vdc | |
| Full-load rated output voltage | 12±0.2 | vdc | |
| Short term maximum output current | ≥5200 | mA | |
| Output current | 5000 | mA | |
Output Features(24V/2500mA)
| No load rated output voltage | 24+0.2 | vdc | |
| Full-load rated output voltage | 24±0.2 | vdc | |
| Short term maximum output current | ≥2700 | mA | |
| Output current | 2500 | mA | |
| Output over-current protection | Output 110-180% of maximum load | A | |
