AC to DC 15W 5V9V12V15V24V power switch supply power converter module HLK-15LO05E/15LO09E/15LO12E/15LO15E/15LO24E
Visitor2251
Price$4.06
Global universal input voltage(85-305VAC)
Low power consumption, green enviroment protection, no-load loss<0.5W
| Working Temerature | -40—+85 ℃ |
| Altitude | ≤2000 m |
| Rated input voltage | 100-277Vac |
| Input vlotage range | 85-305VAC/88-430VDC |
| The maximum input CURRENT | ≤0.4A |
| Input inrush current | ≤34A |
| Input frequency | 44-440Hz |
| External fuse recommended | 2A/250Vac, Slow blow |
Output Features(5V/3000mA)
| No-load rated output voltage | 5.0±0.1Vdc |
| Short term maximum output current | ≥3300mA |
| Rated output current | 3000mA |
| Output over-current protection Output maximum load | 130-150% A |
Output Features(9V/1670mA)
| No-load rated output voltage | 9.0±0.1Vdc |
| Full-load rated output voltage | 9.0±0.2Vdc |
| Short term maximum output current | ≥1870mA |
| Rated output current | 1670mA |
Output Features(12V/1250mA)
| No-load rated output voltage | 12.0±0.1Vdc |
| Full-load rated output voltage | 12.0±0.2Vdc |
| Short term maximum output current | ≥1450mA |
| Rated output current | 1250mA |
Output Features(15V/1000mA)
| No-load rated output voltage | 15.0±0.1Vdc |
| Full-load rated output voltage | 15.0±0.2Vdc |
Output Features(24V/625mA)
| No-load rated output voltage | 24.0±0.1Vdc |
| Full-load rated output voltage | 24.0±0.2Vdc |
| Short term maximum output current | ≥825mA |
| Rated output current | 625mA |
